CS 2560 control panel
  • blazebusiness
    SanDiegoCopierRepair.com
    • 1257
    Control panel not responding or touch screen not responding ...... gonna go there and check for the obvious....stuck keys etc. Does this model have a history of problems like this? Any suggestions?
  • Jimbo1
    • Mar 2008
    • 845
    I have had to replace a couple overlays on them. Pack a lunch.
    "Some days you get the bear, some days the bear gets you."
    Cdr. William Riker
      • 23009
      It's very common to get some grit, or perhaps a curl of steel between the edge of the touch screen and the plastic panel opening. If the touch panel is being pressed in one place, the rest of the touch screen is unresponsive.
      I've never had to replace a Stratos touch panel for this symptom. I have had to replace a whole panel assembly for cfB31 errors after loading firmware. =^..^=
      • blazebusiness
        • 1257
        Thanks for responding....I got off easy. Stuck button on panel was the trouble.
