KM 2550 Background with specks.
  • nmfaxman
    • 1702
    Cleaned the drum W/ dispersant, alcohol, water and windshield fluid.
    Seems like charge is causing it, but I am not ruling out DV bias or cleaning blade.
    There was an earlier post that someone had the tech pub.
    Any one have that pub or an idea?
    Thanks.
    • 23010
    If it's been arcing from the primary charge, that drum is toast. There's an off-chance that the primary charge unit may solve your problem. =^..^=
    • JustManuals
      • Jan 2006
      • 9838
      I don't have the tech publication, If you have the name or the number of it, I can get it for you. I DO have the Parts & Service manual. Email me if you want it.
      Paul
      • nmfaxman
        • 1702
        Cleaned drum with dispersant (wow,had some).
        Increased DV bias by 5 and now good copies.
        Thanks for the input.
        • monstott2010
          What type of "dispersant" did you use?
