taskalfa 300ci doc feeder
  • banginbishop
    grumpy old git
    • Oct 2007
    • 894
    have the above doc feeder giving out either white/grey sheets or black sheets on single or double sided copying. Works perfect off the glass and internal prints are fine. Ive updated the firmware, adjusted the dp settings but still the problems there so ive now ordered the ccd.
    Any ideas ladies and gentleman?
    Incontinentia Buttocks
  • Zackuth
    • Aug 2009
    • 448
    I would look at the DP connector and reseat it.
    If at first you don't succeed, redefine success
    • JustManuals
      • Jan 2006
      • 9838
      This Parts & Service manual can now be purchased for $11.77 and downloaded immediately after payment from The Internet's largest collection of manuals
      Paul@justmanuals.com
      • JSC
        Gimp
        • Dec 2006
        • 618
        Have you looked at swaping the cable that connects the DP to the machine, I've had one an a TA250ci giving strange faults, although not the same faults as you are getting.
        The gene pool could use a little chlorine.
        • alpha-omega tech
          • 80
          Check to make sure the scanner lock is not pushed in. I have see this do this kind of problem.
            • 23010
            Which DP, DP-750 or DP-760? The 750 scans all images to the CCD. The 760 does dual scan with a CIS scanning the second side.
            In either case, I think I'd make sure that the scanner is stopping under the slit glass. I think you'll find that the scanner is not consistently making it all the way to the slit glass, and is stopping part-way under the white plate. =^..^=
            • randula7
              • 73
              scanner.JPGsee the image red marks and check in the scnner mirror frame its can be out of position
              • banginbishop
                grumpy old git
                • Oct 2007
                • 894
                Got to be the 750 as it does the second side by reverse and there is no cis which is why im leaning towards the ccd. I've watched the paper go through the slit glass and it doesnt stop/jam and like you said i've adjusted the settings from 1 end to the other but with no change as i thought that as well where the image is being blocked by the frame.
                • bronco31
                  • Aug 2009
                  • 174
                  reseat the little DF board in back that got added to the main body when you installed the doc feeder.. i had one jostle loose..
                  Guy
                  • banginbishop
                    grumpy old git
                    • Oct 2007
                    • 894
                    i havent been back to it so i dont know if its been fixed yet. I did order a ccd but someone else went to fit it as its in another engineers area. If i find out ill post the results up.
                    I will add that i do not suspect it to be the doc feeder as it does not have a cis - it uses the optics to scan so im basing it on the doc feeder being mechanical only and not image reading.
