kmc 3225
  • Tebow83
    • May 2009
    • 92
    kmc 3225
    hey guys,
    does anyone know what the fuser life is on the km c3225?? I have one creasing the paper. Just want to be sure before i order.
    Thanks in advance.
  • Jules Winfield
    • Jul 2009
    • 821
    Fusers on that machine are rated for 300K.
    But I'm trying, Ringo. I'm trying real hard... to be the Shepherd.
    • randula7
      • 73
      300K.but its can be damage befor.I have km-c2525/3232
      2 units flat spotted.making noice dok,dok since instalation date and 2 units broken.you can claim warranty.
        • 23009
        The fuser is the usual cause for wrinkling, but I've seen another cause on the Saturn series that may apply to your situation.
        I've got a real estate office that was printing hundreds of pages of labels from tray #1. Miraculously, they managed to remove the various peeled-off labels without damaging the primary transfer belt or the plastic guides. There was a lot of adhesive on the pre-registration guides and registration roller. The pre-registration mylar on the door side was wrinkled pretty badly at the machine rear. And the pre-registration mylar below the registration roller was flipped under the roller. The end result was extensive wrinkling at the registration roller, before imaging. So if you pull open the wrinkles there is no image inside. Wrinkles from the fuser will have image inside the wrinkles. =^..^=
        • Tebow83
          • May 2009
          • 92
          Thanks guys, new fuser did the job. Very pricey fuser though.
