KM 2030
  • tcypy1961
    • 773
    KM 2030
    Copier is ocassionally having 2 vertical line appear on copies. They don't travel the whole lenghth of the page copies are made 8.5x11R. I cleaned the developing unit and replace the M/C corona wire. Now getting look of overtoning. Was this cause possibly by work performed since it was noticable before???
    Thanks!!!
    • 23007
    Most Kyocera machines nowadays are monocomponent.
    When you clean the developing roller on a monocomponent system, any oil residue from the cleaner must be rinsed off with alcohol. After cleaning I usually rinse with alcohol, run developer refresh twice, then dry-wipe the entire surface of the developing roller.
    If it did have anything to do with your cleaning method, the heavy backgrounding will gradually diminish with normal usage. It won't cure itself, but you'll notice a difference.
    Maybe unrelated, but I have had very poor luck with restringing primary's on 30cpm or less Kyocera machines. My guess is that the blocks are beginning to short by then. Let us know what you discover. =^..^=
    • KyoceraChris
      • Jun 2009
      • 112
      if not try a drum cleaning blade.. they are replaceable but if not unit it!!
      you gunna eat yo corn bread?!?
      • anthony123
        • 62
        Hey, are you using OEM supplies? Generics can cause headaches....Ant
