Dual Fax for Taskalfa
  • jazzih
    • May 2009
    • 10
    Hi Experts,
    Need help on the dual fax issue. I have install dual fax kit in the MFP, Can anyone teach me how do I send fax using line 2. Is there a steps or icon in the control panel or setting need to be done?
    Thank you in advance.
    • 23009
    I don't have any of these in the field, but my understanding is that you only transmit on line 1, but can receive on line 1 and line 2 simultaneously. Does anyone know differently?
    • tmaged
      Owner/Service Manager
      • Oct 2008
      • 1889
      When setting a default reception port through the command center, the other defaults to the transmission port.
      Hope that helps !
      -Tony
      www.dtios.com
      Become a fan on Facebook
        • 23009
        Thanks Tony. =^..^=
        • jazzih
          • May 2009
          • 10
          Thanks for the feedback,
          Does this mean I'm unable to send fax using Line 2?
          Or when you send fax, the machine will automactically see if line 1 is busy receiving, it will use line 2?
          • tmaged
            • Oct 2008
            • 1889
            That I'm not really sure about. I just set up the normal "published" fax number as the reception line & the "unknown" line as the sending line.
            Hope that helps !
            -Tony
            www.dtios.com
