taskalfa 300ci jamming
  • D_L_P
    Self Employed
    • Oct 2009
    • 1196
    I had a call today for finisher jamming (082?) and want a second opinion. I only saw it jam once, it had ejected the paper then said jam but there was no paper in it. It cleared and then ran fine again.
    I don't know these very well but I just assumed the false jam was with the exit sensor. When I pulled out the sensor I could see the black patch below was lit up pretty good from an overhead light. I taped a small piece of paper, 1in by 2 in, on the exit guide near the static eliminator to block the light from the ceiling. I don't know if that will fix it or not.
    Can anyone tell me what the 082 means or any common causes of jamming on these finishers?
    Aslo, are they for real with that color registration adjustment in the system menu? Is there an easier way?
    • 23009
    J82 is a stapler home position error, nothing to do with the paper feed sensors.
    There's a lot more to color registration.
    If you're going to do firmware (version 11.0) do it before the color calibration. That will take 45 minutes.
    You'll do a developer refresh, then color calibration, then color registration, then gray halftone adjust. The calibration takes about 35 or 40 minutes. =^..^=
    • Copier
      • Jan 2007
      • 27
      Jam in stapler
      (3000-sheet document finisher)
      The home position is not detected within the specified
      time when driving the staple motor.
      600 ms 600 ms 600 ms
      (Document finisher)
      The staple home position sensor (STSPS) is not
      turned on within the specified time when driving the
      staple motor (STM).
      • D_L_P
        Self Employed
        • Oct 2009
        • 1196
        Thanks guys, I will make it out there tomorrow and check the stapler.
