Task Beta
  • anthony123
    • 62
    [Misc] Task Beta
    They Should have called them task betas, The engine is just like the 3035, 4035 but I keep having strange issues I never had. Oh well onward and upward.....Ant
    • 23008
    I would try to offer some useful commentary, but I haven't yet determined what model it is, or what problem you're having. My psychic abilities must be slipping ... =^..^=
    • CT Copier Repair
      • Mar 2010
      • 304
      Are you talking about task alpha?
      They at least what i have seen are a good machine and i am not even factory trained on them
      • ignacio.cortez
        • Jul 2010
        • 176
        I like the machines, Hate the Event Report, I'd rather have the old JAM and C-CODEs Log with the 2 columns (Total & since last reset counters with the description of the code
          • 23008
          I disagree ignacio. The event log gives new information, specifically copy count, so you can determine if a particular code has popped up 10 times in one day. The old report tells you only 10 times since it was cleared the last time (usually the last PM). Not much information. =^..^=
          • tmaged
            Owner/Service Manager
            • Oct 2008
            • 1885
            I wish they gave date & time like Sharp does on their printouts.
            Hope that helps !
            -Tony
            www.dtios.com
            Become a fan on Facebook
              • 23008
              Canon is the best information. Date, time of jam, time jam cleared, jam location, paper source, paper size, paper output, for the last 50 events. What more could you ask for? =^..^=
              • CT Copier Repair
                • Mar 2010
                • 304
                The relaibility of the old Ir lineup and no more dam fixing films
                LMAO
                • ignacio.cortez
                  • Jul 2010
                  • 176
                  Not quite, im used to resetting the jam and c-codes counters (not totals) on each visit, so I know how many jams or codes have ocurred since the last visit, the new one does not have descriptions, so I have look up the codes i havent memorized yet, that takes time.
