KM-C3232 Gives paper jam
  • Keymaster
    • Feb 2011
    • 15
    [Jamming] KM-C3232 Gives paper jam
    Hi
    One of our clients has a Kyocera KM-C3232 that gives paper jams. We've replaced almost everything on the machine, clutches, rollers, etc. Out of desperation we decided to initialize the machine... end of problem... until now. Does anyone have a permanent fix for this problem? Or can anyone please give me some advice...
  • Venom
    Technical/IT Support
    • Nov 2009
    • 765
    Please post the Jam Codes
    IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
    • kyocera.team
      • Aug 2010
      • 126
      jamming but where and what is the jam's code ?
        • 23009
        This all-clear you performed can be very destructive. Did you print off the maintenance report, then re-enter all that data you cleared? I thought not. =^..^=
        • Keymaster
          • Feb 2011
          • 15
          You're right we didn't we only re-entered things like date, time, etc.
          Is it harmful to initialize the machine, if done alot?
          I will also post the jam codes I am just waiting for the other guy at the office to bring them to me.
          • Keymaster
            • Feb 2011
            • 15
            The jam code is JAM 31
            • jmaister
              certified scrub
              • Aug 2010
              • 755
              oh [censored]!
              j31 on taskalfa's can mean new transfer unit. I dont know if old series has the same problem.
              Does the paper gets stuffed between the roller and plate on the duplex unit? is there duplex unit?
              CAPTAIN! ZA BELT JUST DONT MOVE!!
              does it happen only on double sided? your fuser and transfer unit both have starwheels? or the paper magically gets folded in between fuser rollers?
              MORE SYMPTOMS, jam code only say so much(naturopath? no?).
              Idling colour developers are not healthy developers.
              • Keymaster
                • Feb 2011
                • 15
                the paper gets stuck in the transfer roller. It happens with single and duplex copies
                • jmaister
                  certified scrub
                  • Aug 2010
                  • 755
                  transfer belt is shot, take it out for inspection.
                  the transfer belt isnt turning, therefore the foam roller isnt as well, but the rubber roller is still pushing the paper upward, therefore the unique paper jam.
                    • 23009
                    Agreed. When you remove the primary transfer belt you'll find that one of the rubber inner tracks has come off and is entangled in the idler pulleys. By the time the transfer belt is completely stalled, usually it will have wrinkles or worn holes in the belt.
                    And yes. Throwing away all your image registration and color calibration data does not do any good for your copy quality. =^..^=
                    • Keymaster
                      • Feb 2011
                      • 15
                      Thnx for the help. I am on my way to the client and I will try it
