fs-c1020mfp locked up
  • lightningjeremy
    • Jul 2009
    • 139
    the machine flashes processing and printing on display. nothing seems to be helping. have repowered and left unplugged for a few minutes. is there some sort of all clear on this machine? please help. thanx
    • 22995
    Have you tried re-loading the firmware?
    • Jude
      • Oct 2009
      • 256
      post an email and I will send the manual
      • madas
        • Aug 2008
        • 313
        Hi,
        Had a KM copier doing the same sort of thing. I done a U906 just for the sake of it and that got rid of it and has been ok for more than 6months now. hope this helps.
        madas
        • dickierock
          • 252
          Had the same problem,brand new machine installed at customers,locked up twice in first week,firmware fixed it
          • lightningjeremy
            • Jul 2009
            • 139
            i have not done firmware on one of these. what does it take? lightningjeremy@comcast.net
            • madas
              • Aug 2008
              • 313
              Originally posted by madas
              Hi,
              madas
              please ignore this as it appear this model does not have the option for U906..
              madas
              • lightningjeremy
                • Jul 2009
                • 139
                thanx for the info you emailed, but it was for the wrong model. i am working on an fs-c1020mfp. how do i upgrade the firmware?
                • madas
                  • Aug 2008
                  • 313
                  Hi, Format a usb stick on your pc then load firmware onto that. turn m/c off plug the stick into the usb slot at the front open the front cover and turn on m/c. let it run until completed is displayed and turn m/c off remove stick and turn back on and that is it. print out a status page before doing firmware and then after to see if it has changed. it may not have changed depending on version available but at least you have refreshed it.
                  hope this helps.
                  madas
                  • lightningjeremy
                    • Jul 2009
                    • 139
                    there is no usb slot in front
