the machine flashes processing and printing on display. nothing seems to be helping. have repowered and left unplugged for a few minutes. is there some sort of all clear on this machine? please help. thanx
fs-c1020mfp locked up
Tags: c10, clear, display, front cover, fs-c1020mfp, ignore, left, locked, locked up, mfp, printing, processing, sort, usb
Have you tried re-loading the firmware?If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^= -
Had the same problem,brand new machine installed at customers,locked up twice in first week,firmware fixed it
thanx for the info you emailed, but it was for the wrong model. i am working on an fs-c1020mfp. how do i upgrade the firmware?Comment
Hi, Format a usb stick on your pc then load firmware onto that. turn m/c off plug the stick into the usb slot at the front open the front cover and turn on m/c. let it run until completed is displayed and turn m/c off remove stick and turn back on and that is it. print out a status page before doing firmware and then after to see if it has changed. it may not have changed depending on version available but at least you have refreshed it.
hope this helps.
madasComment
