Hello Friends, when I use DUPLEX MODE 2 sided copy the image of the first side and 2 side SHIFT UPWARDS about 1 inch, while using normal copy mode 1 side the print is ok no shift from anywhere I check it from all Trays the result is same ,the prob comes only when USING DUPLEX MODE, I also CLEAR ALL MEMORY but still no result,
i dont takek a maintenance report before i do this
so please sent
U034 > LSU OUT LEFT
U067 > ADJUST DATA1 to adjust scanning centerline, and ADJUST DATA2 for centerline of rotated images.
Third, you'll need to run simulation U072 > DATA (simplex) to adjust DP centerline first side, DATA(duplex1) to adjust DP centerline for first duplex page second side, and DATA(duplex2) to adjust centerline for second and later duplex second sides.
which you enter
Please I need help.
rajvardhanpandey@gmail.com
so please sent
U034 > LSU OUT LEFT
which you enter
Please I need help.
