C-2000 Kyocera Taskalf 520i
  • Techman1000
    • Dec 2010
    • 44
    Has anyone seen this, I have a TASKalf 520i that wil run 30 to 50 copies than you get a C-2000 code Drive motor failure. I'm at a lost this copier is only two months old with about 128,000 copies on it!
  • Techman1000
    • Dec 2010
    • 44
    I'm still having problems with this copier, swap out main motor, PWB board, checked wirring, what else power supply!!!
    • Metalvoc
      • Sep 2008
      • 155
      Haven't seen it on the taskalfa, but I have seen this code come up repetitively on the FS-9530. We replaced the drum unit and never saw the code again. I would check your motor drive assembly to make sure there are no missing teeth in there, and nothing is binding up, if you haven't already.
      I must have a prodigious quantity of mind; it takes me as much as a week sometimes to make it up - Mark Twain
        • 23009
        Sorry, I can't help. That's one code that I haven't seen. =^..^=
        • bensdad
          try checking the left hand door interlock switch i think its the same as a falcon1 and 2 and if the actuator doesnt quite hit the microswitch you will get that code. good luck
          • SPBE
            • Sep 2010
            • 70
            Yes, replace the drum
            • JustManuals
              • Jan 2006
              • 9838
              Just Manuals | The Internet's largest selection of manuals | Instant Downloads
              Paul@justmanuals.com
              • Techman1000
                • Dec 2010
                • 44
                Re: C-2000 Kyocera Taskalf 520i
                This copier has benn shut down since end of May, its in a School so I suspect we still have this issue to deal with!
                • Venom
                  Technical/IT Support
                  • Nov 2009
                  • 765
                  I had one with same issue, was the drum unit starting to seize, replaced drum unit and fixed
                  IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
