Heads Up on VoyagerE
    • 23010
    After replacing the Main Drive Pack, I got a C5101.
    The book says "Incorrect Vpp values during initialization" and "Replace Black Primary Charge Assy." Seems simple enough ... but that wasn't it.
    I swapped yellow primary with black primary, hoping for a C5103, but it stayed C5101. Then I replaced black and yellow primarys, still C5101.
    Figuring that I must have caused it, I pulled the back cover. The very last component that I put back on was the black drum motor, and there was the connector just dangling there, never re-attached. Apparently the drum must turn to correctly read Vpp (whatever that might be). It's funny that it did not identify a drum rotation error.
  • Joe_The_Techie
    Re: Heads Up on VoyagerE
    Thank you very much... I was pulling out my hair, turns out there was a small dent in back panel, touching and stopping the M drum motor getting a C5103.
    • Kidaver
      Ghoulscout
      • Apr 2011
      • 912
      I have never been more annoyed with myself when I swap a drum or dev unit on one of the Color TA200-500 machines and forget get to plug something in or not plugged in enough....put it all together and turn it on and get an error and smack myself in the forehead knowing what the problem is.....and to make it worse do it more than once....
      "In a cruel and evil world, being cynical can allow you to get some entertainment out of it."
        • 23010
        I'm glad it saved a few of your valuable hairs. =^..^=
        • JR2ALTA
          • Feb 2010
          • 2033
          With all due deference to the Cat, making sure to plug in all the connectors is hardly a "head's up". But hey, sometimes the codes can be misleading.
          • brecht2
            • Feb 2012
            • 71
            Hello folks!
            I can't find following service codes: 5101 ->5104 in the kyo service manual...
            I've C5104 (yellow) on a TA 400ci.
            I swapped the drum motor with another one but no result.
            Anybody knows how to find a solution about this kyo error codes?
            Why they're not in the manual??
            Thanks!
              • 23010
              Originally posted by brecht2
              ... Why they're not in the manual??
              Thanks!
              You must not have a complete manual. Please contact Paul. He can get you the correct manual, complete. www.justmanuals.com
