Taskalfa 500ci/ Finisher
  • tech07
    • Aug 2008
    • 410
    [Jamming] Taskalfa 500ci/ Finisher
    I seem to be posting too often lately and not answering posts instead. Been to alot of schools lately so maybe I' not focused right now..Well, I have a 500ci with a 3000 sheet finisher that records alot of Jam88 codes ( main tray eject ). I have not been able to reproduce or even see it happen, but it's there in the event log. Anyone see this often? I have a new sensor coming but anything you guys have seen on a regular basis? See alot of other finisher jams but not J88..
  • aabarnes1
    • Mar 2009
    • 620
    Try firmware.
    Grant me the serenity to accept the things I cannot change.
      • 23010
      The closest that I've got for you is J87, caused by one of the plastic inlet guides to the stapling tray breaking off the rear post.
      I'd also check that the stapled set eject belt is functioning properly. =^..^=
      • JSC
        Gimp
        • Dec 2006
        • 618
        I have had to carry out the procedure on the attached bullitin a few times.
        Hope it helps.
        The gene pool could use a little chlorine.
        • tech07
          • Aug 2008
          • 410
          Thanks guys..I looked intensly for a tech bulliten on this. Q&A is not that user friendly.. I think JSC found just what I'm looking for..thanks. Now maybe I can go back to helping here instead of asking for so much help..Off to new Kyocera product school in 2 weeks..
          • Kidaver
            Ghoulscout
            • Apr 2011
            • 912
            Tell them to quit leaning on or sitting on the finisher as they are copying seems to fix a lot of finisher jams in the TA line....
            "In a cruel and evil world, being cynical can allow you to get some entertainment out of it."
