KM5050 with periodic black page
  • axyun
    • Aug 2007
    • 1323
    Customer called this AM with occasional total black page. I would guess that the drum unit DK-716 would be most likely candidate to solve this problem. I was going to order the MK-716 and start with drum unit. Any helpful advice and information would be very much appreciated as I have minimal experience on this model. Frank/ActionPhotocopy
  • banginbishop
    grumpy old git
    • Oct 2007
    • 894
    Re: KM5050 with periodic black page
    yep - drum unit giving out intermitent blacks, possibly the charge unit but if its under warranty send it all back
    Incontinentia Buttocks
    • axyun
      • Aug 2007
      • 1323
      Thanks Paul. Frank
        • 23009
        It's usually the primary only (sometimes as simple as a stuck wire cleaner), but like bangin says, take advantage of any warranty you've got. It's not uncommon to get pinholes in these drums when the primary starts arcing. Also make sure the drum drive coupler isn't gunked up and not returning. Don't use conductive grease as that will add resistance to the drum ground. Use a little light oil to free up the coupler. =^..^=
        • axyun
          • Aug 2007
          • 1323
          Thanks for the additional info david. Frank
          • ragajungle
            just had 2 of these. Corona wire. in one case last year I was able to clean and reseat but the issue came back again so now I just replace the wire assy. 302GR94530 is PN
            • axyun
              • Aug 2007
              • 1323
              Thanks for the help raga. Frank
              • kyocera.team
                • Aug 2010
                • 126
                change or clean the MC 710 ,good luck
                • axyun
                  • Aug 2007
                  • 1323
                  Yay team!!! Thanks . Frank
                  • ragajungle
                    Your welcome...
                    @ blackcat^^^ aren't those drums rated for a million clicks?
                    • dickierock
                      • 252
                      Think its more like 500K.
                        • 23009
                        Originally posted by ragajungle
                        Your welcome...
                        Like dickie says, 500K. But in real life, and with some charge arcing they can last as little as 180k.
                        The harder you run them, the longer they last.
                        Depending on the size of the drum, Kyo's ASi drums last anywhere from 300k to 3M anticipated yield. =^..^=
