cfooo
  • djs
    • Jul 2025
    [Dead] cfooo
    taskalfa 305 freezing on WELCOME screen. Replace black cable between op panel and main board
  • JustManuals
    • Jan 2006
    • 9838
    Re: cfooo
    Paul@justmanuals.com
      • 23008
      Re: cfooo
      Thanks djs. It's added in.
      • Metalvoc
        • Sep 2008
        • 155
        Re: cfooo
        That is good to know. Thanks! I also noticed... ummm, I mean a friend of mine told me... that if you switch the black and white usb cables that plug into the engine pcb on a 250ci series, the copier freezes at the welcome screen.
        I must have a prodigious quantity of mind; it takes me as much as a week sometimes to make it up - Mark Twain
        • jmaister
          certified scrub
          • Aug 2010
          • 755
          Re: cfooo
          seriously?
          arent they just cables?
          Idling colour developers are not healthy developers.
          • kkendric
            • 301
            Re: cfooo
            On the TASKalfa 250Ci series the white and black USB cables connect to the Main PWB not the Engine board The engine board is mounted behind the main PWB. The main board is also labled as to where each of these connectors is to be connected. Locking up at start up screen can be caused by almost anything that interrupts the data between main board and the operation unit. The F-DIMM's, usb cables, etc.
            • Metalvoc
              • Sep 2008
              • 155
              Re: cfooo
              Yes, the main board. I think that's what I said... I plugged - I mean, my friend - plugged the usb cables into the main pcb wrong. yeah, that's it!
