CS2550 Still the Same!!!
  • Glen
    • May 2025
    This thing is driving me nutso! Don't know what to do next....new drum, devel.,fuser, rollers and lots of cleaning!
    Getting only about the one third (1/3) of the print and it is light. This has simply got to be an easy fix! There HAS to been some little thing I've missed!
    If you help me from checking into the looney-bin, I'd appreciate it so much!
    Thanks!
    Glen
  • laserman06
    Conservative in Exile
    • Dec 2007
    • 323
    Have you thought about the High Voltage board? I have a fellow tech that I work with that had the same problem. Turned out to be the HV board.
    The family that prays together, stays together!
    Smile God created you and He doesn't make mistakes!
    Relax, God IS in control!
    Be still and know that I am God
    Ps 46:10
      • 22930
      Charge
      I've not seen this problem, but I'm leaning in the same direction. I'm thinking about shorted primary charge.
      • 10871087
        • Jan 2005
        • 1143
        Transfer roller not seated correctly or missing a spring? I have seen them cause density problems on the falcon series of machines.
        • just a tech
          • Jan 2007
          • 332
          i agree with 10871087.. had one the other day with very light print..found one of the springs missing from under transfer roller and roller wasn't seated properly..(no wonder customer said it was also jamming a lot..lol )
          • leroyal
            Expert on The Obsolete
            • Sep 2007
            • 156
            Pirate Toner?
            I know what I know better than anyone else knows what I know.
            • raym
              • Apr 2005
              • 62
              i agree with the transfer roller assembly/springs also. i told glen about that the first time he posted this problem. he either didn't read my reply or it didn't fix the problem, but i have myself, seen this exact issue before. it drove me nuts for an hour or so too.
              ray
              • SupertechNCISpfld
                crazy mita
                transfer roller/ optics / laser unit. jake
                • Moreorles
                  Have you isolated the area of the problem. Did you do a sky shot or all black copy and then checked the drum. If the drum is covered in toner,then the Charge unit is working and the dev unit is ok. Leading you to a transfer problem. As the other techs have said check the transfer roller and pressure springs
                  • anthony123
                    • 62
                    What up
                    Hello Ant. Does the machine have a feeder?
                    Is the problem the same from the contact glass?
                    Is the copy half light and then blank?
                    did you all ready post a more detailed description of the problem I did not see one? .....Ant
                    • anthony123
                      • 62
                      Glen send me your email your phone number and I will try and help you out. reid007@embarqmail.com ....Ant
                        • 29376
                        try cleaning the laser unit
                        yes inside
                        • Sathsayin
                          • 21
                          check the output from the hv board with your meter. Like everyone else im leaning toward the the transfer roller. Alot of times the plastic tabs holding the roller in place will break from slamming the door on the side. thiss allows the springs to pop out but the tabs spin around the plastic roller staying attached.
                          Make sure that you look to see which spring is which if this is the problem one is black the other silver. They do matter.
                          Just for the heck of it try flashing just in case some settings are out of whack with the shadeing position and not the shader itself. Software gets corrupted from brownouts and spikes are if you have a weak capacitor on your board.
                          I want to choke the axxhole who designed this!!!!
                          • techman
                            • Dec 2007
                            • 49
                            Try using OEM toner and replace the developer unit along with it.
                            • gpoffmachs
                              techie
                              • Feb 2005
                              • 55
                              look real close at the transfer roller assy. copystar uses a black clip on the transfer roller. only find it in the parts man
                              i would recommend 302ft93090 transfer roller assy
                              dont forget to verify your contacts
                              Techie
