Kyocera/Copystar 500C
  • lorenrupe
    The Great Land
    • 57
    We keep getting a Jam code 50 once in the morning most mornings. We have replaced the exit unit, a one way drive gear in the Job Seperator, and the fuser. We have also updated firmware. After we changed out the exit unit it worked for a week and then started back up with the jam 50 code.
    Any ideas would be most appreciated!
    Loren Rupe
    Valley Business Machines Inc.
    • 23009
    Re: Kyocera/Copystar 500C
    I had a VoyagerE just last week doing the same thing (J50). It turned out to be a bad/intermittent overflow sensor (the last flag/sensor before the top tray. I took a chance on a sensor out of a used unit, floating around in the back of the vehicle. It started working immediately.
    I can't explain why the new unit would act up, but I can understand why the sensor would fail over time. It's exposed to the fuser heat in that location.
    The other thing I would look at is the gray driving rollers on the underside of the exit section. The individual rollers can shift off center and start to drag on the adjoining fins. A clue is the gray "eraser dust" in the paper path. Again I can't image a new unit having this problem, but who knows? =^..^=
    • copygirl
      • 75
      I know it's been a week but I just saw your post. I'm sending you a bulletin on the J50. Hope it helps.500ci-400ciENTB8R2.pdf
      Ginger
      • lorenrupe
        The Great Land
        • 57
        Thanks Blackcat! We had already switched out that sensor but he had used a used one so we went ahead and replaced it again and so far we have not had another jam code but on this machine sometimes it may take a week or 2 before it happens again so time will tell? Also to copygirl we did have the bulletin and replaced the parts and upgraded the firmware like it said but no help! Thanks for the comment though!
        Loren Rupe
          • 23009
          My fingers are crossed for you. =^..^=
          • tmaged
            Owner/Service Manager
            • 1888
            I had one doing the jam first thing in the morning. I don't recall the jam code, but I ended up replacing the job separator & that took care of it.
            Hope that helps !
            -Tony
            www.dtios.com
            Become a fan on Facebook
