Have a KM 3050 that detects tray 1,detects paper size but the tray motor does not work.<br>Switched motor en switch and paper feed from tray 2 with no result.<br>Did U906 no result.<br>On the display you wil see tray 1,but when selecting this it wil say remove paper and say tray is not avaiable.<br>I can only guess that the engine pwb is the problem.<br><br>
KM 3050 tray lift up motor problem
Re: KM 3050 tray lift up motor problem
Did you try switching the paper trays and the feed assemblies between the two trays? If it is telling you to remove the paper, it may be that the paper size detection switches are all activated, or the machine thinks that they are. Make sure there are no switches stuck or broken behind the cassette. You might try swapping those one at a time as well.
If you have tried all of that, you could worry about the engine board, but before you replace it, just try re-seating the connectors. I am always weary of blaming circuit boards until I have traced the problem back that far. I have unfortunately replaced more than one circuit board that was perfectly fine.I must have a prodigious quantity of mind; it takes me as much as a week sometimes to make it up - Mark Twain -
It's extremely common for a shorting lift motor to take out the motor control circuitry on the engine PWB. Replace both as a set to solve this problem. =^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^=Comment
I had the same problem with a 4050 replaced the lift motor and engine board then loaded current firmware. It has been working fine since then.Comment
Thanks all,
replaced motor and engine board pomblem solvedComment
Congratulations on a successful fix. =^..^=If you'd like a serious answer to your request:
