Mita KM C2520 error code C6000
  • copyman
    Owner / Technician
    • Sep 2005
    • 4524
    A few weeks ago this machine had a C6030 code. I tried to reset but code came right back. Installed new fuser unit and reset. Was working great for last few weeks. Customer called this morning and machine now has C6000 code. I had them try and reset over the phone but it wont reset. The service manual isn't much help. Any help appreciated. Thank you
    • 22929
    Re: Mita KM C2520 error code C6000
    Something has caused another blown thermal fuse, in the fuser.
    Could your customer be copying with the lid open, or heavy fill edge-to-edge images? Those prints tend to roll up into the fuser and get between the thermistor and the heat belt, resulting in C6xxx codes.
    Some general purpose things to check are:
    Has the fuser temperature been adjusted up? Set to default.
    Are the fans operating, blowing in the correct direction, and filters clear?
    Is your customer running unusual media type or size?
    Unfortunately for you, these fusers come as assemblies only. No individual parts sold. =^..^=
    • copyman
      Owner / Technician
      • Sep 2005
      • 4524
      Thanks blackcat. I will check out what you posted.
      I know this fuser is only sold as complete unit. Is it possible to take apart and rig with a standard thermal fuse? Have you ever tried to take unit apart?
      I may have to try and repair since they just paid $600 for the fuser 2 weeks ago.
      Thanks again
        • 22929
        It depend how lucky you are. If it's the thermal switch on the frame, I hear that it's the same as the one on the Falcon III. Unfortunately, the one that usually blows is inside the heat belt. Not much fun to change, if you've got a scrap one to install. =^..^=
