The TA 8000i fuser problems
  • CompyTech
    Super Tech
    • Feb 2011
    • 706
    Around 75-100k the fuser seems to fail. Especially the belt. A bulletin was released last week 10/7 with new firmware to correct the codes. Anyone else running into these problems too? Just a bad design flaw of fuser units I guess.
  • CompyTech
    Super Tech
    • Feb 2011
    • 706
    Re: The TA 8000i fuser problems
    Just had another one fail today. The fuser belt was shredded. Wow!
    • jmaister
      certified scrub
      • Aug 2010
      • 755
      I've heard KM/CS put a bounty on any dmg belt.
      They want samples ASAP.
      Idling colour developers are not healthy developers.
      • monstott2010
        Just had one fail last week... and of course, no fusers available and no pm kits available... had to scream like a banshee to get one located to get customer up and running again... received a shim in the mail yesterday that is supposed to fix the issue, we'll see
        • CompyTech
          Super Tech
          • Feb 2011
          • 706
          Same thing.
          • RCR
            • 11
            This is a big problem also in the european market.
            During the rotation, the belt shifting to the rear side of fuser unit.
            The problem is the position of the adjuster plate of the fuser unit but at
            this moment I don't know the correct position of the plate
            I'm waiting a Service Bulletin about this problem.
            • toner head
              • Sep 2010
              • 10
              The problem is the frame of the machine. Currently there is a jig from the manufacturer that will properly align the fuser for longer life. There is no part number for the jig at this time.
              • RCR
                • 11
                Yes I confirm this, I'm waiting for jig to the end of september. I hope that the problem will be solved....
                • rashid120
                  • Jun 2010
                  • 76
                  kyocera modified the Fuser assembly.please check the technical bulletin and replace with the new one.your problem will not repeat.
                  Thanks and Regards.
                  Rashid Iqbal
                  • JSC
                    Gimp
                    • Dec 2006
                    • 618
                    Thanks and Regards.
                    Rashid Iqbal
                    You still need to adjust the position of the frame the fsr unit slots into even with the modified fsr units. I think there is only a few jigs in Europe, but if you carry out the attached modification it should be the same as using the jig.
                    The gene pool could use a little chlorine.
                      • 23009
                      * Be careful by carrying out not to push too much strongly in this case.
                      Don't you love the translation?! =^..^=
                      • JSC
                        Gimp
                        • Dec 2006
                        • 618
                        Don't get me started on Kyocera bulletins, every one they release I have to read a dozen times before I can make any sense of them..........
                          • 23009
                          And what about this? My first thought is, "... don't do it like this."
                          They do not show removing the jig. Are you just supposed to leave it in there? It does not look necessary to hold the final placement.
                          • JSC
                            Gimp
                            • Dec 2006
                            • 618
                            There is no jig!!!! they are trying to show how to adjust the front side home position for the fsr......Take the bulletin next time your at a 8000i, read the bulletin, look at the machine, re-read the bulletin, do this about 4 or 5 times, then say WTF why don't they just say loosen the screws, move the plate untill it is at the correct position, tighten the scews back up. It takes about 30sec to do the ajustment once you have removed the fsr and about 4 days to work out what the fuck they are talking about in the bulletin.
                            • toner head
                              • Sep 2010
                              • 10
                              So son, but not only have I seen the jig, I used it on several machine to correct the problem. How would you know the correct position to unwarp the fuser. I have no reason to lie to anyone. It is an aluminum milled block that fits into the frame and correctly aligns the fuser. It is not an alien,,it really does exist.
