taskalfa 400ci
  • sharptech1
    • Oct 2011
    • 163
    [CQ] taskalfa 400ci
    What can I do to fix the black coming out gray in color mode and the blue coming out pink? B/W looks fine. I tried all the adjustments in the menus. Thanks for any help.
  • ES-OGT
    • Aug 2011
    • 129
    Re: taskalfa 400ci
    If you look under the color tab on the copy screen there's an option that allows you to make copies with individual colors and primaries; Cyan, MAgenta, Yellow, Blue, Red, and Green.
    Try that for each color and see if any give you a problem. Then check the appropriate dev unit.
      • 22934
      Re: taskalfa 400ci
      Like he said. My guess is Cyan. =^..^=
