KM-8030 - Thining Letters
  • GSX115
    • May 2025
    Hey! =D
    My company recently purchased a few KM-8030s for one our new locations but we've noticed that it prints things strangely bright and also thins out characters. Not really sure what the problem can be but this happens in both network printing as well as making copies on the local machine. We've done some test prints between the 8030s and some of our 4035s and the difference is noticeable. Thanks and any help would be appreciated! =D
    • 22943
    If you rotate the image and the copy paper, does the image compress exactly as before, or on the other axis?
    The drum drive motor may be turning slowly (possibly because of a flipped drum blade or some other mechanical drive problem). This is probably the only cause that would affect prints and copys, and compress the image in the feed direction.
    • 10871087
      • Jan 2005
      • 1143
      Originally posted by GSX115
      Hey! =D
      Being that they are new, I would imagine you have a maintenance agreement in place on the equipment. I would recommend calling your dealer and having them take a look at the machine.
        • 29468
        has a fine line adjustment in one of the defaufts
        also Dev units can also produce lighter images, do to a toner sensor wiper problem in the units
