how configurate the scan???? KM 3035,4035,5035??????
  • peredosam
    • Aug 2025
    I have 3 models of Kyocera km 3035-km5035 and I have a problem when I tried to configure the scan mode. I entered the correct password and then pushed the next button "basic configuration" but it comes a label "unable scan". I have tried to return to the basic configuration, wait aprox. 2 min but nothing happened. Can somebody help me? Thanks. Samuel
  • JR2ALTA
    • Feb 2010
    • 2033
    Re: how configurate the scan???? KM 3035,4035,5035??????
    You need to have a network cable plugged into the scanner board.
    Unlike the printer settings, you must be connected in order to access the scanner configuration.
    Or, if you are new to kyocera you might not realize that printing and scanning are transmitted through two separate NIC cards.
      • 23009
      100% agree. You still have not specified what type of scanning you're trying for: SMB, FTP, Email, or TWAIN. Each is set up totally differently.
      "Scanning" covers a lot of territory. Please be specific. =^..^=
      • peredosam
        i want cofigurate TWAIN and Email Scan tks.
          • 23009
          I hope I didn't upset you by asking exactly what you wanted.
          Well, I really don't care that much. =^..^=
            • 23009
            OK,
            Firstly, make sure that you have a network cable connected to the scan card.
            Secondly, assign an IP address to the scan card (open/unused address different than the print card).
            Thirdly, Access the web interface to enter: SMTP information, default sender address, any addressbook entries.
            Fourth, Load the TWAIN utility to the server or any PCs you intend to run the TWAIN application from:
            Look here:
            The TASKalfa 305/255 can dramatically lower your TCO total cost of ownership...Kyocera's SMARTtech is affordable
            If you need a Spanish language utility, you'll need to find that yourself (my Spanish is not good enough to find my way through the menus):
            Is this it?:
            Kyocera Color Laser Printer Copier Scanner Fax MFP Products
            Once loaded, the TWAIN utility will need to be configured to find the scanner.
            Enjoy! =^..^=
            • kkendric
              • 301
              Strange way to ask for help.
              • russmacman
                Remembers 900d (redtop)
                • 19
                Are you asking for scan to email, folder (and or SMB?) Let me know. Russ
                • peredosam
                  yes i want cofigarate the scan to the email (smtp) and to folder. tks.
                  • goldencup
                    • Nov 2008
                    • 366
                    Hi! try this link maybe you can get something. A lot of our good friends here helped me on the same problem
                    http://www.copytechnet.com/forums/ky...p-scanner.html
                    • russmacman
                      • 19
                      OK lets start. I assume that you can get on a browser page from the IP of the scanner correct? If so look on the left side for you email settings. You will need your SMTP host name or IP address. (try the address first, sometimes you need smtp.xxx. sometimes not) Check the port, as default is 25. If your SMTP server is an exchange this should be all you need for this part. You may not need a login name and password if the exchange is not relaying out the LAN. If your SMTP requires SSL, you should stop here. Scanner card wont work with SSL. After your register on the bottom, look on the left again and add your name and email address under sender. Register. Look on the left and add your name and email again under email address. That should get you close. If you get an error under history on control panel, let me know. Scan to folder work well also if you want. Will need a program called scanner file. I can send to you. Please send a private message to me and I can send that ( 4 megs or so, and a screen shot on how to configure it that i made up). Russ
