km 250ci
  • T911
    • Jun 2007
    • 628
    km 250ci
    memory light is flashing...... all works but fax system. did a 906/163/600 and 601 but no luck. ideas appreciated. thanks T
  • Eric1968
    • 2458
    Re: km 250ci
    Did you install the memory module, or maybe the memory isn't installed the right way.
    • T911
      • Jun 2007
      • 628
      Re: km 250ci
      reinstalled too.
      • Zackuth
        • Aug 2009
        • 448
        Re: km 250ci
        Do you have the ability to test with another fax module?
        If at first you don't succeed, redefine success
        • KYO_OEM
          • Aug 2011
          • 726
          Re: km 250ci
          any C-calls on the event log?
          C0620/ C0650?
          Did you try 671?
          Any other applications are working in the background ?
          Greetings KYO_OEM
          • T911
            • Jun 2007
            • 628
            Re: km 250ci
            Originally posted by kyo_oem
            any c-calls on the event log?
            C0620/ c0650?
            Did you try 671?
            Greetings kyo_oem
            no 6000 codes and i didn't do 671. But doesn't everything get initialized when you do 600/601.
            Thanks t
              • 23010
              Re: km 250ci
              Have you upgraded the firmware since the fax has been installed?
              The firmware on the various accessories is rarely at a suitable level new out of the box. I make it a rule to upgrade or at least re-load firmware whenever an accessory is installed. =^..^=
