laser unit KM-8030
  • dikyo
    • Apr 2011
    • 45
    laser unit KM-8030
    Hi ,
    We have a customer with a KM-8030 ,they have already made more than 4.000.000 prints.
    the machine works fine but there is one big issue.
    We have replaced the laser unit (LK-650B) 7 times, because c4200 en C4120 codes.(resetting no possible)
    When I replaced the LK ,I set the 3 values in U472 ,then everyting looks fine an after a couple of months (2-8) the errorcodes are coming back.
    Every suggestion is welcome
  • Zackuth
    • Aug 2009
    • 448
    Re: laser unit KM-8030
    I had this problem with a 8030 once. The new laser threw the same code and answer for me was to replace the charge grid. You might want to try that and perhaps the entire charge unit and see if that helps.
    If at first you don't succeed, redefine success
    • Geo
      • 662
      Check the DV unit frame ground, they ware out.
        • 23009
        Like Geo, I've had the developing bias contact on the imaging frame rear cause this code. Just remove the developing unit and examine the contact at the rear that contacts the end of the mag roller.
        Do not use any kind of lubrication on this connection. It will cause light or blank prints intermittently. =^..^=
        • dikyo
          • Apr 2011
          • 45
          Hi,
          Thanks guys,
          I am gonna back next week to the customer and check the developer ground.
          Hopefully is the 8th laser unit not necessary.
            • 23009
            Watch for something like this:
            There is also a tech pub regarding faulty wiring harnesses, and improper wire routing. Be sure to read up on that before you head out.
