Can a KM5050 rotate sort like this?
  • copyaction
    • Oct 2007
    • 985
    Have a customer who just replaced a Ricoh Aficio 700 with a KM5050.
    I have it set up to rotate sort with 1 drawer 11x8 1/2 and the other 8 1/2x 11 and it rotate sorts fine when copying.
    He wants it to "rotate sort" when printing from his email, a document with 20 attachments so each attachment comes out in the opposite direction. He says he had the Ricoh set up the same way and it was doing it.
    I couldn't find a setting on the 5050 that would provide this, am I missing it or can it not do it?
    • 22999
    Re: Can a KM5050 rotate sort like this?
    Give this PreScribe command a try:
    !R! JOBP 11,1; EXIT;
    enables rotate collation for printing. If you need to reset it to Off:
    !R! JOBP 11,0; EXIT;
    If you need help sending PreScribe commands see post #7 of this thread:
    http://www.copytechnet.com/forums/ky...tre-login.html
    Let me know if it works for you. =^..^=
    • copyaction
      • Oct 2007
      • 985
      thanks, will try it.
        • 22999
        The thing that I wonder about, is if the machine will rotate sort only multiple sets of prints, or if it will rotate sort single pages of multiple print jobs. I'm curious. =^..^=
          • 22999
          So how did this work out for you copyaction? =^..^=
          • copyaction
            • Oct 2007
            • 985
            I emailed the instructions to the customer but he said he would have to get his IT guy to try it.
              • 22999
              I guess I thought you were doing it. This seems like it's a little beyond the skill level of most endusers. =^..^=
