kyocera e023 scaning code
  • digicor
    • Jul 2008
    • 1153
    Kyocera km6030 e023
    This code pertains to smtp server not working,, the smtp server is working???? can someone tell me what is going on? we thought the port was blocked,, nope,, i have tried every smtp server i know that i use, no matter, still the e023. I have scan to file no prob. I set up scan to e mail on a regular basis and ive never encountered this code.does this km6030 have to have a third party software or program besides the scanner utility/address book??
    2) where can i find a read me file
    on the scanner utility? ive been setting this thing up on my own for ever, ide like to know a little more about the ins and outs if possible.
  • JustManuals
    • Jan 2006
    • 9838
    Re: kyocera e023 scaning code
    Go to the Kyocera site and see if there is a manual to download covering network setup. If you can't find it, let me know and I'll get it for you from their internal site. If I get it, it won't be free but it will be reasonable. Shoot me an email and I'll see what I can do.
    HtH
    Paul@justmanuals.com
      • 22999
      You'll have a problem if this is an off-site email server. The NS30 scan card is not SSL compatible. =^..^=
      • digicor
        • Jul 2008
        • 1153
        ok that makes sense then, is there a compatible scan card for the machine as a replacement?
        or
        should we just go with an e mail third party software program?
        thanks for the info
        • ES-OGT
          • Aug 2011
          • 129
          What kind of network are you working with here? Do they have a server on site and if so what is the OS? If they are using an external SMTP server and they have a server on site, SMTP is very easy for an IT tech to install on a server. So if they have a server AND an IT guy have them install it internally.
          • habik
            • 2013
            What if they require SSL?
            Firmwares HERE
            • Jules Winfield
              • Jul 2009
              • 821
              Then you're SOL...
              But I'm trying, Ringo. I'm trying real hard... to be the Shepherd.
              • digicor
                • Jul 2008
                • 1153
                so the bottom line here is the km6030/8030 does not handle ssl and needs an external program for email in today's age of security? no matter what external smtp you use it has to have ssl,(Gmail,hotmail,roadrunner ect..)
                so the solution is to run an email program as a relay to the outside smtp that will do the ssl for the machine.
                correct?
                so there really is no solution with firmware update to this nic card.ok.
                anyone have an e mail program they recommend that they have used and are satisfied with?
                thanks for all the info.
                  • 22999
                  There's a third party software called "Stunnel". I don't know much about it, but I think it will solve your problem:
                  stunnel: stunnel - multiplatform SSL tunneling proxy
                  • habik
                    • 2013
                    Thanks BlackCat for this brilliant info. Appreciate it!
                    Just one thing..do you know anyone who tried it.. successfully?) I got no knowledge of this ..but is soo tempting as I need SSL solution.
                    Firmwares HERE
                      • 22999
                      I was directed to it by a forum member, but have never actually tried it. Sorry, no details. =^..^=
                      • digicor
                        • Jul 2008
                        • 1153
                        Thanks Ive Passed the info over to my client and he should pass it over to his IT guy.
                        well see what shakes out..
                          • 22999
                          Keep us posted on the results. =^..^=
