this machine will soil the backside of the copy 2-3 inches into paper path with UNFUSED toner. the front of the copy looks fine. generally only happens on the first copy of a run. pressure roller cleaning roller is making contact and turning correctly. machine is not giving any fuser errors. any ideas??
copystar 3010
bigdogs501
One word for you......UPGRADE.. All the 3010/2310's I've seen do that. Talking with other mita techs and support there isn't much of a fix for it. That's what you get for an upside down process..Sorry. -
ITCHYFINGER
I Agree With The Transfer Roller Assm. Replace It. If You Want To Check To See If This Is It, Vaccum Out Built Up Toner Under Roller In Housing. Then Take A Tooth Brush And Brush It In 1 Direction Only. You Should See The Grain Of The Foam Come Back And The Roller Changing To A Lighter Gray Color.Comment
Copiersrus
