reset password km8030
  • msmy
    • May 2010
    • 123
    [Dead] reset password km8030
    Hi,
    I'm new in KM world. I heard that KM8030 is a good machine. So, last week I bought 2 used KM8030 (imported from Germany) and the machine arrived this morning. How ever, when I on the machines, both of them need password. Please help me to tackle this problem..
    thanks
  • JustManuals
    • Jan 2006
    • 9838
    Re: reset password km8030
    Paul@justmanuals.com
    • Claudio
      • Feb 2007
      • 235
      Dont remember exactly but check info. In your manual..You can try sim 21 or 20. It should reset network settings and at the same time get rid of password. Since you just got the machines it shouldnt matter resetting all network settings
      • Zackuth
        • Aug 2009
        • 448
        The job accounting might be turned on. To turn it off
        Press the System/Counter key
        Press Job Accounting
        A screen with 4 boxes will come up, enter the password 6200 for TA620 and 8200 for TA820
        Press the job accounting button
        Turn the Job Accounting, the buttons under Job Accounting, off.
        See if that works.
        If at first you don't succeed, redefine success
        • msmy
          • May 2010
          • 123
          See if that works.
          Hi,
          I on both of the machines today. But, both of touch screen not respond at all, which is not respond when I touch. please help me..
          • Zackuth
            • Aug 2009
            • 448
            Sometimes grit can get inbetween the plastic edging and the touch screen making it unresponsive. Take a small, thin something, I use the blade on my small pocket knife, and insert bewteen the plastic on the display screen, and the touch screen without damaging either, and go all the way around. If that doesn't work, the touch screen might bo out of alignment. Get into the maint mode and perform a maint 201--initialize the touch panel. This can be done through the key pad and not the touch screen. There will be a plus sign, touch the center of it with a closed pen or stylis. Other plus signs will appear, I think there are 3 total including the first. When this is done exit the maint mode and test the touch screen. If this doesn't work, replace the touch screen.
              • 23009
              I don't much like the idea of the pocket knife anywhere near the tablet, but the rest is true enough. It's extremely common in the spring and fall to replace several of these tablets. =^..^=
              • umer_ml
                • Sep 2012
                • 24
                open front door of the machine then turn on and type from keypad 10871087.machine will in the maintenance mode then 20 21 option reset machine.thats all
                • Zackuth
                  • Aug 2009
                  • 448
                  I know, but it is the thinnest thing I carry. If I can remember to get something else thin and strong enough to put it in my bag I would.
                  • kkendric
                    • 301
                    Replace touch screen, $ 54.00 from Mita. Don't these machines have a default log in 8030 = 8000, 6030 = 6000. If a previous customer entered their own then you will need to perform a simulation 20 to ser the machine back to factory defaults.
                    • msmy
                      • May 2010
                      • 123
                      thanks guys. Solved the problem. Changed with new touch screen and reset password as suggested.
                      cheers.
