Copystar FS-1035
  • ACMTech
    [CQ] Copystar FS-1035
    Yellow line when scanning using the document processor, no lines when scanning off glass any ideas?
  • Jules Winfield
    • Jul 2009
    • 821
    Re: Copystar FS-1035
    I would start by cleaning out the DP...
    But I'm trying, Ringo. I'm trying real hard... to be the Shepherd.
      • 23010
      Yellow stain on the slit glass? Remove the slit glass and hold it up to the light, or place it over white paper. The dirty spots become painfully obvious. =^..^=
      • JR2ALTA
        • Feb 2010
        • 2033
        some of these machines will have colored lines appear in your scans.
        extremely annoying and hard to fix.
        setting scan setting to BW won't help.
        you'd think a copy would have the exact same lines only black, but no it just effects scans.
        i have read on dnet that you need to order the color calibration chart from kyo.
        also, crack open the optics and clean all the mirrors.
        • madas
          • Aug 2008
          • 313
          Hi, I have had several FS-1128's cause a line only seen on scan's.
          I adjusted U68 from 0 - 20 this adjusts the DP read position.
          This cured all of the m/c's I have seen with this fault.
          If it happens from the glass also then there may be other adjustments
          if cleaning does not solve the issue
          madas
          • JustManuals
            • Jan 2006
            • 9838
            Paul@justmanuals.com
            • Raymann
              • Apr 2015
              • 73
              Thanks for the tip
