rollers for pf 750
  • spokc
    • 35
    rollers for pf 750
    in the parts book i see the sep roller but i don't see the feed roller,the roller that is right above the sep roller
    does any one know the part number
    also is there a part number for the entire feed unit of the pf 750 mine has over a million feeds and i would like to just replace the whole thing
    thanks
    • 23010
    Re: rollers for pf 750
    (2) 5A707600 Pickup Roller (1 ea)
    (1) 5FH06010 Feed Roller (total 1)
    (1) 5FH06020 Separation Roller (total 1)
    (1) 54106150 Separation Torque Limiter Rear Hub
    (1) 5A707670 Separation Torque Limiter Spring, Greasable
    (1) 54106170 Separation Torque Limiter Sleeve
    (1) 5A707620 Separation Torque Limiter Front Hub
    (2) 5A707640 Separation Spring (1 ea)
    (4) 305A707971 Feed Clutches
    At 1M prints I would replace these items:
    • spokc
      • 35
      thanks is there a part number available for the entire feed unit
      it would seem more efficient to replace the entire unit as opposed
      to putting all those individual parts int the old unit
        • 23010
        No assembly number listed. Even so, I doubt it would save you any money.
        Watch that the plastic tabs are not broken:
        http://www.copytechnet.com/forums/ky...-pf-750-a.html
        • spokc
          • 35
          thanks for you assistance what plastic tabs are you refering to?
          time is the money i like to save and a new unit would be a million
          prints better than an old one if it was available.
          • GESPAGE
            • May 2011
            • 40
            hello, check
