Kyocera KM-3060 Cable Connect Issues
  • Crystal
    • Jan 2013
    • 29
    Hi everyone, I have a customer with a Kyocera KM-3060 that has intermittent problems with the document feeder. We are trying to find a part # and diagram for the cable connector that connects the document feeder to the back of the machine. Does anyone know where I can get that info? Thanks!
  • rnrfisherman
    Re: Kyocera KM-3060 Cable Connect Issues
    the cable itself? or the connector plug?
    • Crystal
      • Jan 2013
      • 29
      It's the entire cable that runs from the doc feeder to the back of the machine - male to female
      • Crystal
        • Jan 2013
        • 29
        I think it "might be" PN# 305H68166 but without a parts guide to look at, we just can't be sure....
          • 23009
          I've never ordered one ... but from looking at the DP-670 manual I'd venture an educated guess that you're correct.
          • Crystal
            • Jan 2013
            • 29
            Can you send me just that page of the manual that shows the diagram and the part #? We've already ordered the wrong part # once. I'm at crystal_data@hotmail.com
              • 23009
              You're in luck. I'm not always so close to the manuals.
              The pix are deceiving. It's the name that confirms it: INTERFACE CABLE
              • Crystal
                • Jan 2013
                • 29
                I think that's probably it too. Funny thing is we even called Kyocera tech support and they couldn't find the correct part number either! It's just really hard to tell if that's the signal cable or not.
                  • 23009
                  Tech support is a last resort when you've already exhausted your own resources. If anything useful comes of it I'm pleasantly surprised. =^..^=
                  • rnrfisherman
                    Sorry was on a call... have replaced that cable on a DF-670...solved the issue...Good Luck!!
                    • rnrfisherman
                      One other thing... have to dig it up... there was a bulletin issued about a ground strap... or extra wire to eliminate random static...
                      • Crystal
                        • Jan 2013
                        • 29
                        Thank you everyone for all of your quick responses this morning. We're going to go with the 303K546050 part. I love this site!
                          • 23009
                          If it's a separation issue you're addressing, have you tried the new style separation kit (303K594080)?
                          If the pickup roller is not raising, it's common to see either a broken torque limiter spring (3HL07110), or a cracked pickup roller holder (303K507051).
                          • tmaged
                            Owner/Service Manager
                            • Oct 2008
                            • 1888
                            We've had to replace the cable on one of these also.
                            BTW, in the past, I was told by the hotline, they don't have access to the parts manuals. I called to verify a part I was unclear on, and they said Dallas does parts & NJ does service.
                            Hope that helps !
                            -Tony
                            www.dtios.com
                            Become a fan on Facebook
