When trying to select cassette 3 (High capacity paper tray) the display shows the error: "Paper Cassette has failure Tray 3"
In the setup area of the menus, to select a default tray, tray 3 doesn't show up as an option. Only trays 1 & 2 show up.
The motors do not lift the paper into position, therefore I can not select this tray for my high volume copying. What is the most likely cause of this? Any help would be appreciated.
Thanks.
Thanks.
