TaskAlfa 300i image problem
  • spiderman76
    • Mar 2009
    • 59
    [CQ] TaskAlfa 300i image problem
    Hi Guys !!!!!!!!!!!!!
    I've a TaskAlfa 300i () with the image problem (see attachment ) .
    I've changed the fuser roller but without solving the problem .
    HELP ME !!!!!doc20130417143952.pdf
  • Zackuth
    • Aug 2009
    • 448
    Re: TaskAlfa 300i image problem
    We had a 3060 doing the same thing. What the issue was that we had non OEM toner in the machine. A new developer and OEM toner fixed the problem.
    If at first you don't succeed, redefine success
      • 23010
      What is the interval between repeating images? =^..^=
      • T_foot2
        • Nov 2011
        • 22
        Try running 11x17 and get to stop just as it starts out of fuser. Looks like drum/ cl. blade to me.
        • kyogenius
          • Jul 2012
          • 136
          As blackcatt rightly put it check the interval btwn the repeating images,that way u can figure out if it's from drum or fuser unit,you might need to check if the fuser rollers are sitting correctly as well.Generic toner could also do that but less likely,but wrong toner can do that because of differences in fusing temperatures.Hope this might help.
          failure is not an option !
          • Geo
            • 662
            Check your fuser temp setting , they may be too low for the type of paper being used.
            • spiderman76
              • Mar 2009
              • 59
              Interval is 93-94 mm . Fuser and drum have the same
              circumference !!!!
              • Zackuth
                • Aug 2009
                • 448
                IS the fuser dirty or blackened around the same area the image problem is? If not, replace the drum.
                • marley
                  • Sep 2010
                  • 58
                  non-genuine toner
                    • 23010
                    circumference !!!!
                    Measure again. The drum is 95.5mm and the fuser is 98.5mm. Neither is 93-94mm. =^..^=
