Kyocera km3050,"loading program"
  • RWAFA
    • Aug 2011
    • 68
    HI GUYS,im here again with that problem of my machine kyocera km3050,i have downloaded the service manual of the machine and was going through the manual i did get the page which talks about the firmware update,if i switch on the machine it shows a massage,"LOADING PROGRAM"and it remains like that,please help im stranded.is there any other ways of updating the firmware?
    • 23008
    Re: Kyocera km3050,"loading program"
    What method are you using to load the firmware? Compact Flash or USB?
    If CF,
    1) have you formatted the card on a FalconIII machine?
    2) have you extracted the firmware and copied it to the root of the drive?
    If USB,
    1) is it 500MB or less in size, without other files or programs running?
    2) is the firmware extracted and copied to the root of the drive?
    Once the memory is prepared:
    1) is the machine turned completely off before installing the memory?
    • Rolandito
      • Aug 2007
      • 90
      let me know you email. I will send you the firmware
      • RWAFA
        • Aug 2011
        • 68
        ,MY EMAIL IS rwafawilson@yahoo.com,will be very glad to receive the firm ware,thnkx in advance.
        • evest
          • Aug 2008
          • 58
          Can anyone sell or send me KM5050 Firmware. My email is raschk@sbcglobal.net
          • Rolandito
            • Aug 2007
            • 90
            done....share it by my google drive
            • RollingROARANDA
              • Nov 2012
              • 72
              Just unzip the firmware to a blank FAT32 usb drive ( I've done plenty of these for Kyocera) , it will create a folder on your usb drive containing the firmware files. Open that folder, press Ctrl+A on your keyboard, for Select All, Cut, and navigate to the root of the drive , Paste..
              Delete the empty folder on the drive. Safely eject it. Turn the main power off on the machine. Plug in the USB drive on either the side of the panel or the USB port on the back, either way, and then turn the main power on the copier. It should start updating automatically, and it will stop at a screen informing you of the update results. Power off machine. Unplug USB drive. Power On.
              If the machine still doesn't get past Program Loading, after firmware update, I remember one of my buddies fixed this by re seating dimms or something like that. Sorry I cant be more specific, I only do firmware, hdd, network scan, and print driver issues, and HyPAS, etc...
              • RollingROARANDA
                • Nov 2012
                • 72
                I might just give everyone on this thread firmware, I tried to play nice and help Paul, but he snatched up all my Rep power for some stoopid reason. If he only knew half the *** I fix in a day.
                • evest
                  • Aug 2008
                  • 58
                  Thanks rolandito for the firmware. I'm usually a Toshiba guyif you need anything like firmware or manuals let me know.
                  • etsh_sh
                    • Oct 2019
                    • 2
                    I also need this firmware Kyocera KM 3050..Thank you,...My E-Mail is Etsh.sh1@gmail.com
                      7 year dead thread.
                      what makes you think you need firmware?
                      • etsh_sh
                        • Oct 2019
                        • 2
                        Can i get this firmware for KM3050?
                        etsh.sh1@gmail.com
                          • 8145
                          etsh.sh1@gmail.com
                          We can supply you with this firmware file(s) should you still need it.
                          Feel free to drop us an email enquiry.
                          Kind Regards.
                          www.copierfirmware.co.uk
