Kyocera 300i makes dirty copies ONLY through ADF....
  • Kyocop
    • 69
    Kyocera 300i makes dirty copies ONLY through ADF.... when placed on the glass copiers are just fine. Perhaps light is slipping in someplace?
    Anyone see this phenomenon before? See attached scan.
  • CompyTech
    Super Tech
    • Feb 2011
    • 706
    Re: Kyocera 300i makes dirty copies ONLY through ADF....
    Yes I have. There's an adjustments for the DP in the maint. mode. Forget which one(I think its black line something or other). Look in the service manual for mode list. Sometimes setting the value to default will solve it.
    • Zackuth
      • Aug 2009
      • 448
      I saw at the left that the letters are stretched. This has to do with DP height adjustment. It might also be the cause of the dirty copies. Before you change settings, I'd fix the height first.
      If at first you don't succeed, redefine success
        • 23010
        Ditto that. =^..^=
        • Kyocop
          • 69
          We adjusted the height and one or two other things and now it is good to go. Thanks for the responses!
