Too many compatible being sold for Task alfa 3550CI. Have had problems ourging system, Background issues. I hate to have to change dev. Any Ideas?
Cheep toner
Larhal
If all else fails read the Service Manual!
If that fails, meet me at the pub and we will discuss it. -
Re: Cheep toner
We've learned the hard way about cheap toner. If you don't want to change the developing unit, vacuum out the unit and put in OEM toner, you might have some issues early on, but they will disappear, unless the develping unit was damaged somehow by the cheap toner.If at first you don't succeed, redefine success -
Re: Cheep toner
Thank you. I will do this and purge this crap out.Larhal
If that fails, meet me at the pub and we will discuss it.Comment
Re: Cheep toner
I do not work on the TA's , but , if this is a dual component system .... you will not be able to vacuum the dev ...
You would probably do better to install a new Dev , and charge them for that DV and your time . Them ask them if they want to keep using the generic toner or buy OEM toner from you .
P.S. They killed the warranty by using generic toner .......
And , I bet this is not covered by contract either ...."The Serenity Prayer" . . .
God grant me the serenity to accept stupid people , the courage to not waste my time and energy on them , and the wisdom to know that I cannot fix STUPID .Comment
Re: Cheep toner
The boss said to try to salvage it without a dev change so I cannot argue. I think maybe he supplied the toner!!! Thanks for all your help.Larhal
Re: Cheep toner
I know generic toner is a little different chemically, but I have successfully depleted wrong color toner installed on the VoyagerE series (without changing the developing unit):
Install correct color toner cartridge. Run ~75 100% fill single color prints to deplete the incorrect toner in the developing unit. Perform color calibration. =^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^=Comment
