KM-c2525e Touch screen info needed
  • fshead
    • 2360
    i d like to know if anyone has used the aftermarket control panels that were offered by a European company, that posted on here...is it
    cost effective after shipping charges?
    is it just the tablet?
    Also
    i have a accnt with a km c2525e that the screen wont respond again,fussed with it 6 months ago and got it running,and need to go today.
    my question is i have the tablet but cant find the sponges or sheet,"they are somewhere",can i do this repair without the sheet n sponges?
    thnx
  • kkendric
    • 301
    Re: KM-c2525e Touch screen info needed
    If the sheet is not damaged why replace it. If you are careful and patient you can remove and re-use the sponges.
      • 22999
      The sheet is entirely cosmetic. If it's still transparent, and not ripped go ahead and continue to use it. The main reason I replace it, is that if you're going to charge $250 to replace a tablet, it should look new, right?
      The sponges can start to disintegrate with age. For the < $1.00 each, I replace them. It's not worth the bother to fuss with them. That's just me.
      The sponges must be present however. Think about it this way: at $150.00 per hour, your time is worth $2.50 per minute. If you spend 10 minutes or $25 saving $4 in parts, how does that make sense? =^..^=
      • fshead
        • 2360
        thnx for the replies..
        i got it running "again" w/out changing anything..
        the only reason i wasnt changing the sponges and such is
        not based on $..
        i had a complete set but cant find it all...
        and if i needed to get them running for more than simple copying
        i had to make a decision..i will reorder the sponge seals and sheet
        and do it right..
        thnx again..
