TA 5500
  • Larhal
    • 609
    [CQ] TA 5500
    Hi all,
    I have 6 Task Alfa 5500 that have CQ problem. They are dropping toner on the top half of the pages and have background on the lower half of the pages.
    We use only Original toner, no compatible. I looked on the KYO web site and found a bulletin on something similar, which included a firmware upgrade, Jan 2014.
    Did what the bulletin said and still have the problem.
    Called technical support and they said Dev and Drum change. Did this and still the problem. doesn't happen on the slower machine only on the 5500.
    Any Thoughts???
    Anyone else see this??
    Thanks,
    larhal
    Larhal
    If all else fails read the Service Manual!
    If that fails, meet me at the pub and we will discuss it.
    • 23010
    Re: TA 5500
    Tell us a little more about this bulletin. What exactly did you do? =^..^=
    • Larhal
      • 609
      Re: TA 5500
      SB-2LC-0129-D265 TK6305.pdf
      Hey Blackcat,
      Please see attaches. It is for a firmware update and in the area discussing the fixes, 2, 4, 5, it describes the issues. followed it exactly.
      Larhal
      Larhal
        • 23010
        Re: TA 5500
        Try this one:
        • Larhal
          • 609
          Re: TA 5500
          Thanks Blackcat,
          I have already done this one and used the revised method, New and Improved.
          I have also checked everything that is on the trouble shooting guide.
          Checked the small transfer belt, etc.
          The only thing I am going to try is another batch of Original Toner to see if there could be an issue there.
          Going to the customer now, I will keep you updated.
          Larhal
          Larhal
          • Larhal
            • 609
            Re: TA 5500
            Hi All,
            Tried an new batch of Kyocera Original toner, No issues. Had to do about 50 sky shots and all cleared up.
            I guess they had an issue with the toner. Will be sending it back for evaluation.
            Thanks for all your help.
            Larhal
            Larhal
              • 23010
              Re: TA 5500
              What color or colors is the toner dropping on the page? =^..^=
              • Larhal
                • 609
                Re: TA 5500
                This is a mono machine, so black.
                Sorry I didn't say TA 5500i
                larhal
                Larhal
                  • 23010
                  Re: TA 5500
                  Yeah, I knew that.
                  I went off on a tangent. Many of the latest monochrome machines are constructed exactly like color machines without the CMY. And on a color machine primary transfer belt waste is brown colored.
                  But none of that matters because this monochrome machine is not constructed that way. Ignore me. =^..^=
                  • Larhal
                    • 609
                    Re: TA 5500
                    Must be the cold weather. :-)
                    Thanks again for all your input.
                    Larhal
                    Larhal
