Taskalfa 4551ci scan searchable PDF?
  • cmpelser
    • Jan 2008
    • 173
    Hi, I've just installed 14 of these machines, replacing old biz hub machines, the biz hubs used to scan pdf's as "searchable" ... What are my options to get the kyocera's to scan as searchable PDF?
    • 23008
    Re: Taskalfa 4551ci scan searchable PDF?
    You'll need Kyo-Capture software/server. Your salesman will have the information. =^..^=
    • daveyball
      • May 2009
      • 314
      I believe there is an option for this model, it has a cost though, you just enter a license code and it makes OCR,d PDF,s
      • tmaged
        Owner/Service Manager
        • Oct 2008
        • 1885
        There is a scan extension kit that makes the machine OCR the PDF's to make them searchable. This should only be used for limited OCRing as the machine is processing the jobs. DMS link can be installed on a server or workstation & does the OCRing on the computer. It's actually a little cheaper than the scan extensionkit & would be the better option.
        Hope that helps !
        -Tony
        www.dtios.com
        Become a fan on Facebook
