Document Feeder On Copystar CS-255 Binding
  • tecchie
    • 120
    Good Morning Gurus
    I have a customer with a Copystar CS 255 with doc feeder issues. when a single original is run through feeder there's hardly ever an issue but when you run multiple originals most of the time as the second original is being fed and the first is around the corner of the feeder and the lead edge has already passed over the contact glass and started into feed exit rollers something is binding up that I cant put my finger on. With covers off and watching the drive system everything stalls and feeder make a high pitch noise like the motors are still trying to push paper but nothings moving. I've replaced feeder maintenance kit (MK-470) removed and cleaned all clutches and ran clutch and motor test through maintenance mode. Runs fine. I'm at a loss. Thanks in advance for any and all help...
    • 23009
    Re: Document Feeder On Copystar CS-255 Binding
    What jam and/or error codes? =^..^=
    • tecchie
      • 120
      as far as the copiers display theres just standard document feeder jam signal with no error code. is there a section in the service mode that keeps a history with more detailed information that I don't know about that I can look up?
        • 23009
        Sim U000 Event Log. It's covered in your service manual. =^..^=
        • Kidaver
          Ghoulscout
          • Apr 2011
          • 912
          There is a shaft inside the cover that opens that turns your feed rollers...there are two hook like catches that holds a coupler in place inside there for that shaft...I have seen these break...if so you'll have to order Parts Cover PF Assy....it's pretty much that whole cover....That is something you might look at...
          "In a cruel and evil world, being cynical can allow you to get some entertainment out of it."
          • tecchie
            • 120
            Blackcat event code under Paper Jam Log are a lot of 9410's which is a DP timing sensor stay jam which is where the original is jammed every time on multiple originals.
            Kidaver I went back out to account to take a look and the tab on top cover was broken allowing the bushing to spin freely. I will try a new cover and see if that does the trick.
            thanks for all the help guys. Much appreciated.
            • tmaged
              Owner/Service Manager
              • Oct 2008
              • 1888
              There are bulletins & firmware updates for the ADF on this machine.
              Hope that helps !
              -Tony
              www.dtios.com
              Become a fan on Facebook
              • tecchie
                • 120
                Thanks Tony. When we first had this problem I did check for updates/bulletins but did not see any but it was prior to Kyoceras update as of 3/13/14. Bulletin General #97 sounds like exactly whats going on with this feeder. I'll give it a shot.
                • tmaged
                  • Oct 2008
                  • 1888
                  Make sure you've got 6.03 firmware also, as it changed the clutch operation for jamming.
                  Hope that helps !
                  -Tony
                  www.dtios.com
                  • tecchie
                    • 120
                    Just to finish this thread with resolution the firmware upgrade and new cover assembly did the trick. Thanks everyone for your help.
