Cleaner for Rollers Suggestions
  • djfenti
    • Nov 2012
    • 20
    In your opinion, what is the best cleaner to use for cleaning rollers?? At our company, we use a product called Cut-Thru. Is a good product but it's $20 a can and you can only get it by the case. So all suggestions would be appreciated. Thanks for reading my post.
    • 23009
    Re: Cleaner for Rollers Suggestions
    I use Contractor's De-Solv-It:
    I've heard good things about WD-40, but don't use it myself. =^..^=
    • ruben
      The New Guy
      • Oct 2012
      • 1203
      Katun Formula K for almost everything. It is not recommended for glass, but only because it can leaves streaks; which can be buffed out easily.
      • JR2ALTA
        • Feb 2010
        • 2033
        when i downsized my tool bag, extra cleaners were the first to go.
        bottom line is if build-up is causing jams, anything including water/windex will work to clean it off.
        this magical revjunator stuff is for the birds. if the tires are bald, replace them.
        • rrrohan
          • Sep 2011
          • 1977
          Electrolube Rubber Roller Restorer
          • Zackuth
            • Aug 2009
            • 448
            We use Martin Yale Rubber Cleaner and Rejuvenator. It works really well.
            If at first you don't succeed, redefine success
            • Vulkor
              • Jun 2009
              • 946
              Got a tech that swears by WD-40. It does seem to work pretty good. Some of us use Simple Green.
              • ZOOTECH
                Senior member of CRS
                • 3375
                WD-40 is good for a lot of rollers, but not so good for others (they will gum up and melt). If unsure, try cleaning up rollers that you are throwing away anyway, and see the results.
                • Mr.Claire
                  • Mar 2008
                  • 49
                  All our guy's simply use a dish soap / water solution.
                  • Iowatech
                    Not a service manager
                    • 3930
                    While soapy water usually works the best for dirty paper feed and transport rollers, I'm one of those people who carries WD40 for cleaning those rollers as it doesn't freeze in the winter. It actually cleans those rollers pretty well.
                    Just don't use it on worn out rollers, it doesn't work at all on those.
                    Also, don't use WD40 on charge rollers, as I've found that stupid and wrong things will happen then. I've never had the guts to try WD40 on transfer rollers, so you're on your own there.
                    • ZOOTECH
                      • 3375
                      Originally posted by Iowatech
                      While soapy water usually works the best for dirty paper feed and transport rollers, I'm one of those people who carries WD40 for cleaning those rollers as it doesn't freeze in the winter. Just don't use it on worn out rollers, it doesn't work at all on those. Also, don't use WD40 on charge rollers, as I've found that stupid and wrong things will happen then. I've never had the guts to try WD40 on transfer rollers, so you're on your own there.
                      It's not good for neoprene rollers for sure (that's the one that will gum up), but for cleaning the resist rollers on Sharps of paper dust, and conditioning the rubber, you can't do it faster or better than with WD-40
                      • stopeon
                        • Aug 2013
                        • 13
                        At our shop we use a product from Stoner - B164, I think. Of course, I don't do the purchasing, so I have no idea how the price would compare.
                        • eason
                          • Dec 2012
                          • 7
                          Usually i use plain water for paper feed rollers.
                          • Kalamar
                            • May 2014
                            • 23
                            • qbert69
                              • Mar 2013
                              • 1152
                              ...for rubber rollers/belts ONLY!:
                              Belt Cleaner at the bottom of the page!
                              PS--also good for cleaning off ink marks off of machine surfaces--exterior, platen white pad, glass, etc. It's fairly gently on plastic--good for removing sticker residue too!
                              REACH FOR THE STARS!!!
                              Konica Minolta Planetariums!
