CS4035E (Voyager) No Cyan on page
  • Xferunit
    • 57
    [CQ] CS4035E (Voyager) No Cyan on page
    My guy has replaced the developer, the drum, swapped drum motors (I've seen the coupling get locked up and not turn the drum), put on a new engine board (unrelated problem, but still...it's ruled out), swapped the xfer belt out, put on a different primary xfer hvps, and a new main hvps. He's pretty stumped, and I admit. I'm not sure what to tell him next. Any ideas?
  • darry1322
    • Oct 2010
    • 817
    Re: CS4035E (Voyager) No Cyan on page
    Assuming : good cyan dev and dev rotation, the HV and tranfer contacts for cyan on the transfer belt are good : I'd maybe go for the laser unit.
    • Xferunit
      • 57
      Replaced the developer already, and it is rotating well. The transfer HV was taken out, inspected, seemed fine, and then replaced anyway. Transfer belt has also been replaced. Just replaced the LSU unit Darry...Issue remains. Thanks for your response though.
      • darry1322
        • Oct 2010
        • 817
        Is it completely blank cyan or just extremely faint? We had a machine with the hv contact for the cyan transfer roller in the belt get deformed so there was very little transfer of cyan from the drum to the belt. If you look along the transfer belt rail ( inside the machine with the belt out ), you will see a small spring loop ( one for each color) that serves as a contact from the HV unit to the transfer roller inside the belt (one for each color). You may already know and have checked this, I don't want to assume.
        • Xferunit
          • 57
          Yeah. We checked the spring leads from the transfer HV. Like I said,we went ahead and replaced the entire xfer HV board, along with the spring leads.
          • darry1322
            • Oct 2010
            • 817
            Figured you had, but thought it worth mentioning...
              • 23010
              I've done this to myself on a VoyagerE and a Saturn. I got too rough installing the transfer belt assy, and dislodged the contact spring. It adds 2 1/2 hours to the call to pull the transfer HVT and re-position the spring. =^..^=
                • 23010
                What you need to do is emergency stop the machine several times until you find out where you're losing the cyan. Is there a developed image on the cyan drum? ... on the primary transfer belt? ... on the paper at secondary transfer? =^..^=
