DP-770 jamming and "eraser bits on originals"
    • 23009
    Jam codes J9600, J9200, J9202
    The consequences are fairly obvious ...
    ... but the cause isn't so obvious. I believe that the white plastic holder is inconsistently molded. The thing is, I don't think that a new part is going to be any more perfectly proportioned. Every one that I've looked at is subtly (or not so subtly) warped
    What I did is measure the distance across the longest part of the belt. At the left, I found 73.66mm. At the right I found 74.33mm. So there's no doubt why the belt is walking to one side, but what to do about it? I added a folded paper shim between the spring and shaft at the short side. You can see it in the photo. I don't know if there is a nice linear formula for calculating the thickness of the shim, but in this one case, to get 74mm even across belt the shim was 1.7mm.
    I believe a new feed belt is called for also.
  • tmaged
    Owner/Service Manager
    • Oct 2008
    • 1889
    Re: DP-770 jamming and "eraser bits on originals"
    201203_B463-3NV-0001s2a.pdf
    Looks like yours has the updated pulley. I'd look at the springs.
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
    • habik
      • 2013
      Does the pulley shaft reach end clips of the holder/ass'y. I'd file it off. If the belt gets used and stretches a bit the stop hook might be uneven on one side.
      or as mentioned by Tmaged check the springs.. I wonder if they are :
      1: same lenght
      2: same strenght
      3: have nice flat bottom on each side. Those springs are bit beefy so the step of the end of spring turning, may slip and cause the spring to look side ways. I had it once on KM8030 ADF and was causing same issue. Springs are weird sometimes.
      Firmwares HERE
      • Tonerkiller
        • Oct 2012
        • 668
        That is the problem you have an old style pulley. The new pulley does not have a ridge on it.
          • 23009
          Originally posted by tmaged
          [ATTACH]27255[/ATTACH]
          The first thing I did was swap the springs. The belt continued to ride to the left.
          The second thing was to flip the big pulley (no ribs, by the way). It continued to ride left. (of course, you can't leave it that way, with the one-way bearing inside)
          Third thing was to flip the small pulley. It began to ride to the right.
          My conclusion was that there was something wonky about the small pulley. Either unevenly bored, or out of round, or uneven diameter. But the replacement part also rode the belt to the left.
          Thanks for the bulletin, by the way. I'll probably order the updated pulley(s), but I doubt that it will make the belt ride much straighter.
          I don't understand what you're getting at. Does it show in the pictures? It the clips are on the shaft, the shaft must be the right length, correct?
          If you're referring to the beige molded holder, the hooks are intact. I have seen them deformed or broken off in other applications.
          ... or as mentioned by Tmaged check the springs.. I wonder if they are :
          1: same length
          2: same strength
          The springs are quite beefy for such a small application, but when I swapped them and the belt continued to ride left, I concluded that the springs were similar enough. Once I've done the shim thing a few times, I should be able to come up with a nice neat formula to predict the size of the shim.
          I appreciate your comments. Thanks. =^..^=
          • habik
            • 2013
            OK. I meant the beige plastic hook end stopping the pulley from coming "off" if per say the belt snapped off completely.
            How about the separation ? Any signs of bad tracking of the belt? Then causing stretching/ driving just one side of the belt harded. Just a bit of lateral thoughts.
            Sent from my iDon't believe in marketing device using Tapatalk
            Firmwares HERE
