Kyocera FS-C 5030N, Error: "supervisor mode - parallel waiting - F010"
Re: Kyocera FS-C 5030N, Error: "supervisor mode - parallel waiting - F010"
I think the first place I would start would be to examine the operation panel. There is a key sequence, if held down during initialization, will enter the supervisor mode. It could be caused by foreign matter under a couple of the plastic keys, broken buttons, worn out or damaged keyswitches, or a damaged operation panel PWB. =^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^= -
asveny
Actually, I'm surprised that with the control panel. For it is almost never used because the expression is controlled by the PC. Do you think I should remove the panel field and undergo a cleaning anyway?
If I have understood correctly, it was in this treads, linked below, to the same problem, right?
http://www.copytechnet.com/forums/kyocera-mita-copystar/71992-fc-c5025n.html?highlight=parallel+waiting+kyocera
http://www.copytechnet.com/forums/ky...cera+FS-C5030N
Would like to try first before I fall apart demolish everything to merge the current firmware. Who can send these to me via email? As a private user, I'm not a login code on the support / download page Kyocera, especially for Firmware and more. Because, unfortunately, only employees of contractors access.Last edited by Guest; 12-09-2014, 01:31 PM.Comment
