FS-C2126MFP
  • RBS
    • Jun 2025
    [CQ] FS-C2126MFP
    Light bands on edges of color prints. Internal printouts are good.
    Did Drum and Developer refresh - - no help.
  • tmaged
    Owner/Service Manager
    • Oct 2008
    • 1869
    Re: FS-C2126MFP
    What's the internal test page look like ? Is it copies or prints ?
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
      • 22999
      Re: FS-C2126MFP
      Tell him about Blow Off. =^..^=
      • tmaged
        • Oct 2008
        • 1869
        Re: FS-C2126MFP
        The Blow Off only works to recover the belt reflectivity for registration. For light solids, take the DV units out & cover the toner ports & shake. If they overtone, run single color skyshots of the overtoned color.
        Hope that helps !
        -Tony
        www.dtios.com
        • D Colour
          • Oct 2008
          • 213
          Re: FS-C2126MFP
          Hi tmaged
          Whats this "blow off" you speak of? We have 3 of these machines we have been unable to repair thanks to shocking registration issues!
          Everything that has a beginning, has an end.....
          • tmaged
            • Oct 2008
            • 1869
            Re: FS-C2126MFP
            Amazon.com: Max Professional 2145 Rubber Rejuvenator - 10 oz.: Automotive
            The belt gets ozone build up & turns white. The registration sensor can't read the patches & the registration keeps getting pushed farther off. I use this product to clean the belt. It's pretty harsh, you can also use simple green, but it takes a lot more scrubbing. After cleaning (or replacing) the belt, run the special registration firmware per the bulletin.
            Hope that helps !
            -Tony
            www.dtios.com
            • Tonerkiller
              • Oct 2012
              • 668
              Re: FS-C2126MFP
              Simple green is the best cleaner for rollers and tires.
