Network Fax driver for TASKalfa2551ci not working on Server 2012
  • Moti M.
    • Dec 2008
    • 8
    Hi
    We have the next problem at one of our customers with TASKalfa 2551ci:
    On Server 2012 R2 Network Fax driver version 4.0.0930 is installed with sharing to 32 bit stations.
    Sending fax from server or windows 7 stations (32 and 64 bit) causes this error message:
  • wragsdale
    • Jul 2014
    • 188
    Re: Network Fax driver for TASKalfa2551ci not working on Server 2012
    Make sure WSD is enabled on the machine.
    • Moti M.
      • Dec 2008
      • 8
      Yes, WSD Print and Scan is enable
        • 23009
        If I remember correctly the fax driver is not intended for installation as a shared driver on a server. It only works as a local driver. =^..^=
        • tmaged
          Owner/Service Manager
          • Oct 2008
          • 1888
          Blackcat is correct. The driver needs to communicate with the MFP and it's not possible on a server/share installation. It must be local.
          Hope that helps !
          -Tony
          www.dtios.com
          Become a fan on Facebook
          • taskalfa
            • Jun 2011
            • 97
            Hi guys, does anyone know if you are able to install a network fax driver for the TA3212i on a 2008 R2 server and have it shared to thin clients
            • tmaged
              • Oct 2008
              • 1888
              No you cannot. See the above posts.
              Hope that helps !
              -Tony
              www.dtios.com
              • taskalfa
                • Jun 2011
                • 97
                Thanks tmaged, just wanted to be certain , I was trying to find compatibility chart of some sort
                  • 30294
                  Make sure driver has manage printer checked also that its IP port is the address of copier Not a WSD port. A local install would most likely be better as user can customize there own fax cover page.
