KM 5050 reg coupling gear holder broke
  • copyaction
    • Oct 2007
    • 991
    Customer called today holding the broken part in her hand. It looks like 2 coupling gears that are driven by the registration clutch
    The first picture is from an intact machine I went and found pointing to the part.
    The second picture is the broken part from customers machine.
    Anyone know how to access this to replace, it looks like the part # is 2FG06083 paper feed housing
  • Kyo fan
    • Dec 2013
    • 368
    Re: KM 5050 reg coupling gear holder broke
    Looks like you need another middle feed unit, since ordering just the broken plastic frame and assembling everything back together would be a nightmare.
    Good luck.
    • copyaction
      • Oct 2007
      • 991
      thanks, that's why I thought it would be a good idea to ask since i never replaced this before.
      I will order the middle feed unit.
      What is involved to get that out?
      • subaro
        • Oct 2010
        • 1274
        This looks like it broke from the middle feed unit. remove the two straps that holds up the door, then remove the cover for the middle feed unit, this is the black plastic just above the arrow in your pic. remove the connector and hold both sides of the middle unit and pull outwards towards the door direction.
        302GR93150 this is the whole unit. middle feed
        your part number is for the housing for the middle feed only. You will have to transfer everthing over, clutch, wires ect. With kyocera, if you are a dealer, you would know most items are cheaper or relative cheaper to replace the whole item rather that individual parts, especially pm kit items.
        • copyaction
          • Oct 2007
          • 991
          thanks, I just ordered the whole middle feed unit.
          • subaro
            • Oct 2010
            • 1274
            [ATTACH=CONFIG]28782[/ATTACH]
            Good luck.
            That's not that bad, it only looks like that in the parts list. I have done this a few times and is relative simple, just pay attention to how you disassemble and your assemble should be ok.
              • 23009
              It's quite easy. You'll do fine.
              While you're there installing, check that the transfer roller bushings are intact, and all the springs there. One of the ways that the middle feed unit gets broken is when the rear transfer roller bushing breaks, releasing the transfer roller. A not-too-observant enduser might slam the left door very hard, in an effort to make the door close over the dropped transfer roller. It doesn't close, but they can do a lot of damage in the process. =^..^=
              • tmaged
                Owner/Service Manager
                • Oct 2008
                • 1888
                We keep a whole unit on the shelf as we've replaced 1/2 dozen at least. They just drop in if memory serves me. No tools required.
                Hope that helps !
                -Tony
                www.dtios.com
                Become a fan on Facebook
                • copyaction
                  • Oct 2007
                  • 991
                  Just wanted to say thanks to all who responded on this.
                  It was a snap just like you guys said.
                  • subaro
                    • Oct 2010
                    • 1274
                    You are paying your respect by showing your gratitude. That is a good thing, hope others will take pattern.
                    thank you.
                    • daveh12
                      • Jul 2012
                      • 157
                      Tip. Super glue works really well on the plastic of the housing on this part. Good to remember if you're ever stuck and don't have the middle feed unit in stock. It'll get the machine up and running with no issues until you have the part.
